メインコンテンツにスキップ
Repair guides and support for your Philips TV.
254回答 すべてを表示
Philips 32PFS6402/12 black screen but audio works!
I own a 4 year old Philips 32PFS6402/12 where I suddenly don't see any image (black screen). I went back to the store and asked if it was still under warranty. Unfortunately, it wasn't. Since I am a little bit handy, I want to try to fix the television.
I searched up on the internet i.e Google and Youtube. I found the service manual (Chassis QM17.4E LA) and some handy Youtube on how to diagnose. So, I diagnosed the following:
-My television STANDBY light goes on.
-Philips Ambilights (lights to the side) goes ON when turning television on.
-I do hear audio coming out of the television.
-I did the "flashlight test", when I shined through the panel, I saw my menu such as "source" or "television channels".
-NO BACKLIGHT. I opened up the back of my television, plugged the power cable in the wall, I did not see any lights shining on the back of my television.
Does anyone know which television part is morelikely faulty and should be replaced to get it working?
Thanks in advance!
UPDATE 6/20/21
Removed the back cover of Philips 32PFS6402/12 TV.
UPDATE 6/23/21
Multimeter - Voltage DC settings
18.8 volts on VLEDS+ #1 and #2 on CN8602 CONN.
UPDATE 6/23/21 PART2
Next diagnosis visualized: CONN 8601 #1 with RED probe and U8601 #1 with BLACK probe (question mark).
There is NO C8601, there is only a C8602 (C8602 is a shorten version of C8601 shorten version see picture) and I cannot identify U8601 on the powerboard.
UPDATE 6/25/21
Powerboard Close Ups
Top Left
Top Right
Bottom Left
Bottom Right
UPDATE 6/27/21
Powerboard back - Close Ups
Top Left
Top Right
Bottom Left
Bottom Right
Found it! Do I need to measure the black circle?
UPDATE 7/1/21
Replacing backlight strips: what are the part numbers?
UPDATE 7/8/21
Replaced the backlights of the TV…
Hooray it works! … wait a sec… I think f* up LOL.
UPDATE 7/10/21
Red circles indicates the ribbons that were opened up and green ones arent touched.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
@lekkervlaai There are two distinct possibilities. The power board as well as the backlight array. Since you do see the menu etc. it is most likely an issue with the actually backlight array inside your panel. Those backlight strips can be replaced by disassembling the panel. (HINT:mark the diffuser sheets so they go in exactly the way they came out). Do a search based on the actually panel, not your TV model. There should be a tag on the panel which identifies its model and maker. Of course, you also want to check the voltages on the power board leading to the backlights. Looks like connector CN8601 or 8602 depending on your model. If you need to, you can always post some images of your boards with your question so we can see what you see. Let us know what you get on those.iFixitでの質問に画像を追加する方法
Update (06/20/2021)
Okay so your panel is a TPV made panel. The backlight strips for your TV are available at places like this and many others I am sure. To check out the voltages you will need a multimeter in DC mode ( and check connector CN8601) Positive Leads on contacts 1,2,11,12 and Negative on the others. Set your meter high since some of those voltages can be in the 130V + range.
Let us know what you find
Update (06/20/2021)
@lekkervlaai it is alway a bit different. Yours is a panel that seems to have been made specifically for your Philips. Some TV’s use a bunch if different panels even for the sane model TV. That is why it is always best to find the label on the panel and search by that number as well.
To check the voltages you can simply check it on the connector.
let us know what you find out. These are not terribly complicated repairs as long as one takes their time and keeps things organized.
If it is your backlight strips the challenge will be to mark the order and the orientation of the diffuser sheets so that is something you already want to keep in mind
Update (06/23/2021)
@lekkervlaai Okay, that would only have been a confirmation of what we are currently expecting. C8601 should actually read C8607. Both U8601 as well as C8607 are actually on the bottom side. Sorry about that. The part with the question mark is a transformer.
We are at a cross road right now. We know it's the backlight. Either the power board (appears to be low voltage since your TV panel would have 3 strips with 7 LED's I would expect the LED voltage to be in the 60V-70V range) or the backlight strips. Now, from what I can tell failed backlight strips are very common for this model. Your power supply appears to be a 715g7364-p02-001-002M hard to verify on your picture :-) and that would be available at places like this. Not sure where you are located so shipping could be an issue. The backlight strip may run you a bit more. I am convinced it is the strips (call it a gut feeling) but due to the low voltage I'd opt for a replacement power supply. I'd purchase from a place that has a no question asked return policy. Just in case....Sorry if this sounds a bit wishy washy but I hate to suggest to you to spend some hard earned money.
Update (06/27/2021)
@lekkervlaai here are the points where you measure the voltage at. Black probe to pin 1 of U8601 (bottom left) Let us know what you get
このアンサーは役に立ちましたか?
スコア 2
20 件のコメント:
@oldturkey03 thank you for your reply! Could you explain me the following:
1) What do you mean with "searching the panel which describes the model and maker"?. I made a picture of my television. Could you point out where I could find it?
2)How do I check the voltages on the powerboard leading to the backlights? If I have a multimeter which parts of the boards, chip, capacitor do I check?
Thanks in advance!
さんによる
@oldturkey03 Thanks for your explanation!
So my Philips 32PFS6402/12 has three backlight strips or more? I saw this one has a pretty fast delivery. https://www.aliexpress.com/item/10050017...
Does this fit? How do you search for the backlight strips? Search on the type of the tv, in this case "Philips 32PFS6402/12"? Or a specific #ID?
I will be back within a couple of days on the voltage part. I do not own a multimeter so I am going to ask some friends if they can lend me one.
さんによる
@oldturkey03, back with an update!
I managed to get a multimeter and posted a picture with the settings that I used (it's been a long time since I used one).
I hooked up the tv into a powerpoint and turned on the tv. I checked CONN CN8602, VLED+ #1, and #2 according to the picture you send. I put the black wire (-) into a screw hole and the other (red wire, +) into the pin. The result is 18.8v for #1 and #2. I have no idea how many volts it should emit, but I guess it's not enough? I posted a picture with the results.
For CONN CN8601, I couldn't measure the connector because it's not visible on the power board.
For CONN CN9101, I have no idea how to measure the volts for that conn.
Am I doing it right?
さんによる
@lekkervlaai yes that voltage sounds a little meager. Can you check on more thing? look at the schematic for the LED driver. Use your multimeter and connect to red probe to C8607 and the black probe to the first pin of U8601 Those numbers are the reference designators that should also be printed on your board. Let us know the voltage on that. As always, use common sense when testing live circuits so that you do not touch anything with bare hands etc.
さんによる
@oldturkey03 thanks for the fast reply!
I am not sure if I understand your next question, so I visualized it by a drawing (see update 6/24/21 part 2).
If my drawing is correct, I tried to find it on the powerboard. However, I cannot find "U8601" on the powerboard so far... (its late 2am, I am going to try when its daylight)
さんによる
15件以上のコメントを表示
コメントを追加
回答を追加する
Jason さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 72
今までの合計 2,705
