My tablet is stuck at RCA’s welcome screen.
My tab is not starting, whenever I start my tab it stucks at RCA’s welcome screen.
सोनाली चोंधे try this first:
1. Make sure that the tablet is actually powered off.
2. Press the "Power" and the "Volume Up" buttons, together, until you see the start-up logo on the screen.
3. Once you can see the logo, release the buttons and allow the device to enter the "System Recovery Mode".
4. Next use "Volume Down" button to get to the "wipe data/factory reset" option When in recovery mode the "Volume Up" and "Volume Down" buttons are how to can navigate and highlight what option you need.
5. Once you have selected the "wipe data/factory reset", press the "Power" button to select that option.
6. On the following screen, repeatedly press the "Volume Down" button until the "Yes - delete all user data" option is what is selected.
7. Then press the "Power" button to hard reset the tablet.
Let us know if it works or if we should continue to assist you with other possibilities.
このアンサーは役に立ちましたか?
No this doesn’t work
Won't work. AT ALL
過去 24時間: 0
過去 7 日: 4
過去 30 日: 20
今までの合計 540
