メインコンテンツにスキップ
2019年5月に発売されたXbox One S All Digital Edition(モデル番号1681)はオリジナルXbox One S(2016年発売)の改良モデルです。このXbox One Sのモデルには、Blu-Rayディスクドライブは付属していません。(そのため前面にディスク用スリットがありません)
23回答 すべてを表示
E100 after hard drive replacement
Hey, I’ve got a Xbox one S All Digital Edition here that is providing the error code E100 00000706 80070002 I’ve swapped the 1TB hard drive out for a similar HDD but the only information I can find on E100 is it’s blu-ray related. Any tips would be really helpful, thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
from what ive gathered its a hardware fault.
since you just installed a new HDD try putting old one back in and see if that works.
if so you may need to properly format the new hard drive for the XBOX to recognize it properly.
especially if the size of the HDD is bigger or a weird size.
check out this handy dandy walk through!
https://www.pcsavants.com/tech-tips/xbox...
good luck!
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
In the link you sent it has a script to correctly format the drive, this was the script I used to replace the hard drive. The old hard drive is gives the same error. Once It gets to applying update during the Offline System update using OSU1 it restarts and then goes right back to E100.
Thank you for taking the time to reply
さんによる
@countcreep try doing the factory reset listed here.
https://answers.microsoft.com/en-us/xbox...
hopefully this will work
さんによる
@logixal The factory reset option provides a beep then brings me immediately back to the E100 screen
さんによる
@countcreep are you enrolled in insider preview ??
さんによる
@countcreep Had exactly the same problem
After about 20 attempts and over a day trying, I was about to give up..
As soon as I put the old HDD in all was fine so the E100 couldn't be a blu Ray fault as everyone says
Then decided it must be the offline update which wasn't right
So I downloaded the older OSU2 update and that worked 1st time... Even though it said it wouldn't be compatible
さんによる
コメントを追加
回答を追加する
James Stephenson さん、ありがとうございました!
統計データ:
過去 24時間: 9
過去 7 日: 40
過去 30 日: 193
今までの合計 2,611
