What are the specs for the power supply for the HP Pavilion dv6500
What are the specs for the power supply for the HP Pavilion dv6500? I have lost mine and want to find a replacement.
Hi @advanhorne,
What is the product number of the laptop as found on the information label on the bottom of the laptop?
Looking at the spare parts for the model range, the adapter specifications can vary depending on the product number.
Search for your particular product number in the list provided by the link above and then click on the number to find the parts.
When you have the parts list for that model variant, find the AC adapter part number and then search online using the part number only to find suppliers that suit you best.
このアンサーは役に立ちましたか?
Thanks for your answer. I will follow up on the links you provided.
input : 100-240v -1.6a (1.6a) 50-60hz
output : 18.5 (18.5v) 3.5 a (3.5a) lps
65w
このアンサーは役に立ちましたか?
Thank you for your answer.
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 210
