メインコンテンツにスキップ
サムスンの主力スマートフォンでNote 8の後継モデル。2018年8月発売。6.4インチのディスプレイと最大512GBのオンボードストレージを搭載。
104回答 すべてを表示
Cellular Antenna Issues Galaxy Note 9
I dropped my Samsung Galaxy Note 9 last October, cracking the screen and display assembly. I replaced the display assembly myself (and replaced the charging port), but ever since have been getting a weaker than normal cell signal. It is typically one or two bars less than my brothers device at any given location. This issue leads to dropped/ unstable calls, failure to send texts, etc. GPS antenna also seams to go offline more frequently. I’ve tried all the software fixes, and am convinced it is hardware related. Where are the antenna locations on the phone? Are they replaceable or modifiable?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
I would replace the charge port and the small coaxial antennas that attach to the charge port. Just make sure you order the right variants according to your model number. I’ve seen customers and other repair shops replace their ports with the wrong variant resulting in cellular issues although the most common symptom was it would say “No SIM”.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
For modern phones, the antennas could be all over the edges of the phone, and multiple antennas are required to ensure proper cellular reception and throughput, so if you have to fix them, fix all of them.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Evan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 21
今までの合計 1,246
