メインコンテンツにスキップ
Retina MacBook 2016からアップデートされたバージョンです。モデル番号はA1534(EMC3099)です。Turbo Boost使用時最大3.6GHzの最大1.4GHz Core i7の高速Kaby Lakeプロセッサ、最大50%高速のSSDを搭載し、最大2倍のメモリをサポートしています。
After Battery Replacement: Keyboard, Trackpad, Audio not working
​​Hello,
I replaced the battery (Battery Model A1705) for my Macbook 12" 2017 (Macbook Model A1534 - EMC 3099). After battery replacement, the trackpad and keyboard and audio no longer work and laptop speed is slower than before replacement and only the power button is working well.
To fix it, I just purchased a replacement for all flat cables such as keyboard and trackpad, LCD, audio, power and replaced all flats cables with care, The Issue not resolved, so I purchased a replacement trackpad and keyboard and replaced them carefully, But the issue is still not resolved.
By research, I found out the reason for the slow speed of the laptop is maybe the CPU on SMC mode and not using all power for safety and protection, As the keyboard is not working, I can not do SMC reset, I just connected the external keyboard and mouse, they are working well, tried to do SMC via external keyboard but it seems not possible or maybe I do not know how to do it exactly.
By the way, with the SMC reset my issue may still remain, So if you have any experience with this issue or if you have any recommendation and solutions please let me know.
Thank you.
Update (06/04/2021)
Update: Result of Macbook Diagnostics: PFM006 and PPN001
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
Hello
Any comment? Any experience?
Thank you.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hello,
I just disconnected LCD flat cable and turned on again, but no chance.
Followings are done without any help:
- REPLACED TRACKPAD/KEYBOARD FLAT CABLE (TWO TRY)
- REPLACED AUDIO FLAT CABLE  (TWO TRY)
- REPLACED USB FLAT CABLE (TWO TRY)
- REPLACED KEYBOARD
- REPLACED TRACKPAD
- RE-INSTALLED MAC OS AND UPDATED TO LATEST VERSION
- DISK UTILITY (FIRST AID DONE)
- DISCONNECTED LCD FLAT CABLE AND CONNECTED TO EXTERNAL MONITOR
- SMC RESET NOT POSSIBLE AS BUILT IN KEYBOARD NOT WORKING, TRIED WITH EXTERNAL KEYBOARD DID NOT HELP
it may need fix something on logic board, something like temp sensor or etc,....but not sure.
any experience with  Result of Macbook Diagnostics: PFM006 and PPN001 ?
Please advise.
Thank you.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My internal speakers, microphone and connected headphones are no longer displayed. But I'm getting the same error messages
Update:
The cable in the audio jack board wasn't completely in. You shouldn't see the white mark anymore.
It works fine now - no error codes.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Talebi さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 325
