メインコンテンツにスキップ
A portable Bluetooth speaker manufactured by Ultimate Ears.
UE MEGABOOM only working when plugged in
Had my speaker for over 2 years now but the charging light stopped working suddenly. The speaker is now stuck at 40% charge and stops working as soon as the charging cable is pulled out.
When I took out the battery and then plugged in the light started blinking but when I inserted the battery again it's still the same outcome.
I have read all the previous questions posted here about this issue and none have a solution. Can I play my speaker like this only plugged in?
Is it bad for the speaker to run on only the wall electricity? as the battery or current going to battery is not working.
Update (06/02/2021)
Any help would be appreciated please guys
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hi,
Try replacing the battery and check if that resolves the problem. Even rechargeable batteries have a lifespan
here’s the Ifixit Logitech UE MegaBoom Battery Replacement guide that will help.
Replacement batteries are available online. Just search for CS-LOE116XL to get results.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It sounds like the charging port is bad or it has some sort of water damage.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I'm sure there is no water damage. Is there any way to fix the connection between the battery and the usb charger?
さんによる
コメントを追加
回答を追加する
Animesh 7 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 19
今までの合計 821
