Why is my phone not charging?
My samsung a31 phone not charging
Well, mobile is not charging is mainly happen because of the bad charger. Now the first thing you should do is to change the charge and then if it is not working then the charging jack of your mobile phone can be the cause replace it from a mobile repairer Your mobile will get starting charge.
このアンサーは役に立ちましたか?
الهاتف دائما يعيد التشغيل والشحن يسقط بسرعة
Try to reset it if it didnt work change the battery
Well you can try the following it might help you out:
このアンサーは役に立ちましたか?
Some times my mobile not charging, after restart the phone it starts charging
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 12
過去 30 日: 41
今までの合計 1,512
2 件のコメント
Solw charging
Ashebir Makunnt さんによる
3 month ago in my phone no charge
=== Update (08/09/23) ===
No no charge is there in my phone
My phone is dead thanks
Adinath Panchal さんによる
