Radiator fan turns on late
My radiator fan kicks on at 220f, works for less than a minute and off it goes. ive changed the thermostat, the sensor on the thermostat and the sensor on the radiator but still have the issue, any suggestions?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 32
When the motor kicks off is voltage still being sent to the motor?
brandon k さんによる
Im not sure, it turns on for less than a minute and off it goes..
William Rivera さんによる
check with a meter and see. If you are getting voltage then the fan motor is bad. If not, you'll have to trace the circuit back from there to find the issue.
brandon k さんによる
