How can I change the display on my LG GS290?
It's a LG GS 290 also known as an LG Cookie Fresh, black version, and the touchscreen is off.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
schoenre, you can check on how to disassemble your phone right here. the service manual can be downloaded from here The only thing to remember that is not in those manuals, you need to warm up the screen with a heatgun etc. to loosen the adhesive around the frame to remove the digitizer. Hope this helps, good luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,399
1件のコメント
which LG phone is it? name or number will help us to help you..
pollytintop さんによる
