メインコンテンツにスキップ
Hi, I am unable to power on
Unable to power on my laptop,even after battery removal
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント:
What happened before it wasn't turning on? did it power off suddenly or after the battery drained?
さんによる
i had the same problem - i could not power on, and had difficulty powering off completely. the power button was flashing slowly along with the caps lock key - the screen was pulsating gently at the same rate. when the mains power was plugged in it would power down completely if i held the power button down, but would not power up.
any way - i loosened all the screws and took off the bottom to see what i could see - and that fixed it!! so i gave it a small clean and pressed one or two things in place in case it was a poor connection - it is now running again.
さんによる
コメントを追加
1 件の回答
Hey Wow,
Are there any indicators when you plug in in to AC power?
Do any lights show up?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
WoWsOmE ViN さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 16
今までの合計 352
