detected by computer but won't turn on after being unplugged
i found an old shuffle while digging around a drawer and wanted to try it out, it syncs and is detected by itunes (flashing orange light) but won’t even function by itself
I had this exact issue with one I was given by a friend a few years back. The internal voltage of the battery has likely dropped to far and it has gone into “sleep” where it will refuse to accept a charge in order to prevent anything bad from happening (battery swelling/exploding). To fix this guy, you will probably need to get a new battery and install it. Not the easiest thing in the world, but it can be done. iFixit has a guide for removing the battery and logic board, from there would need to de-solder the old battery leads and solder in the new one, then re-assemble.
このアンサーは役に立ちましたか?
turns out it just needed a good long charge, everything is good now!
過去 24時間: 0
過去 7 日: 0
過去 30 日: 14
今までの合計 137
