メインコンテンツにスキップ
This is the device page for the Samsung Galaxy J7. The OS that comes stock to the device is Android OS v5.1.
170回答 すべてを表示
Why is my phone not telling me the correct percent of the battery?
This phone (Samsung Galaxy J7,2015) was given to me in 2018 from my dad, just a year later it stopped showing me the correct percent of the battery so it just randomly dies. Even after a battery replacement it still wasnt showing the correct percent and dies at a random percent. And when i accidently dropped my phone and the battery flew out after charging it and it showed 80% to 100%. I got an idea maybe removing the battery after chraging it will fix the issue and kept doing this and maybe itll fix it, but no. So i stopped doing it and just kept it there untouched. And when i charge it from 0% itll show 20%+ and wont go higher than that, so i have to use the phone and let it decrease, itll stay at that percent for many mins until it decreases slowly and ones its low ill charge it and it will charge up to 30%+. This issue is so stressful that i needed some advice on how to fix it. If this is just a software glitch and i need to software update, well i cant since the device just says “The latest updates have already been installed”. Pls help me as i dont want to deal with this again. If i need to plug my phone into a computer well i cant since it died. One more thing this device runs android 5.1.1
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
So it turns out it was fake since fake batteries tend to die after 40%. My battery is fake.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Try turning the phone off, and with the phone off, charge to 100%. Then use it til it dies. Don't plug in a charger, just turn it on again, and let it die. Repeat until won't power on again. Then charge to 100% with the phone off, and repeat. This is how I calibrated my battery readings on my android phone. After 2 or 3 cycles of this your phone should hopefully start recognizing full and empty readings from the battery.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I can recognize when it is at full percent since the charger attached to the outlet is cold. I will give it a shot.
さんによる
Did you replace with a battery from a reputable source? Did this fix the issue?
さんによる
コメントを追加
回答を追加する
LINEN PLAYZ さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 58
