メインコンテンツにスキップ
2004年12月12日に日本で発売されました。北米は2005年3月24日に発売、欧州では2005年9月1日に発売されました。
101回答 すべてを表示
Joy Stick Barely Works. Connection is bad. Advice?
Howdy iFixit! I bought this PSP from the thrift store because it was only $30. (Expensive Thrift Stores here haha). It works really well in most cases except for the joy stick. It hardly responds to movement, and the curser/player when you're using it moves around on its own. If you apply pressure to the PSP in that area, it sort of starts working. From what I've researched, the contact from the joystick to the logic board has separated some, so it doesn't really contact the board that well. That's what I've diagnosed, too.
The problem is, however, that I don't really know how to fix it. Anyone else had this problem before? I think it all happens when the PSP is dropped. :P
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
TommyJames, this guide might help you out. Step 7 and on tells you what to do when the buttons are not working etc....
UPDATE
also, you might check this question. If cleaning it does not work you might have to replace the stick assembly. the part is available here and there are plenty of videos on on youtube.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
+ Very good accurate answer worthy of others referencing to it here on iFixit in the future.
さんによる
Thank you so much oldturkey! I'm gonna try this probably over the weekend. With your help I'm sure to get the PSP working again! :)
さんによる
I tried working on the PSP yesterday. It seemed to have been working really well at first, and then it just went back to not working. So, I think I've got to fidget with it for a while. Thanks so much for your advice!
さんによる
コメントを追加
回答を追加する
TommyJames337 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 2,537
