メインコンテンツにスキップ
Appleによって製造された第四世代目のワイヤレスキーボードです。2015年10月に発売されました。モデル番号はA1644です。
48回答 すべてを表示
1 to 9 and control keys suddenly stopped working
Hey guys. My 1 to 9 keys together with the control key suddenly stopped working. I had a window replacement in my room and there was a lot of dust after it finished and I had to clean it with wet wipes. It worked perfectly after the cleaning for about an hour then I went out for about 2 to 3 hours and when I came back home the aforementioned keys had stopped working. What could be the problem and is there a way to repair it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
If your keyboard has an LED indicator for the Num Lock key, the light should be turned on when the numbers can be typed.
In your case, double-check that the keys themselves aren't clogged with dust or other dirt by cleaning out your keyboard with a specialised keyboard cleaner.
https://www.minitool.com/news/number-key...
Carefully turn the keyboard or laptop upside down and gently shake it. Usually, anything beneath the keys or inside the keyboard will shake out of the device, freeing up the keys for effective functioning once again.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jack さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 8
今までの合計 71
