メインコンテンツにスキップ
Repair guides and support for the 3rd generation of Chevy G-Series vans. Similar vans were produced under the GMC brand. Both used suspension and steering parts from GM's C-series pickup trucks.
15回答 すべてを表示
What can cause our ignition switch to not turn over with key in it
Hi fellas, we recently bought a 1988 Chevrolet G20 camper Van and we were having to wiggle the key to get the ignition to turn over but once we get it to turn it cranks just fine. Today, after trying for hours, we can’t get it to turn over, we tried turning the wheel, we tried getting a new key thinking the key was worn out but it still won’t turn over now. Any ideas on what it could be?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
You need a new lock cylinder. I don't know all the specifics about your vehicle (like engine size etc) but I did a search based off what info was provided. You're looking at $20 or less at an auto parts store. I've posted a pic so you can see what I'm talking about. The cylinder is worn down so the keys aren't aligning everything as they should. A new key won't help much because the wear is also on the pins themselves. Replace that and you should be right as rain.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Maura さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 163
