メインコンテンツにスキップ
The LG Stylo 3 Plus is an Android smartphone released in 2017 by T-Mobile. It features a 5.7-inch HD display, 32 GB of storage, and runs the Android 7 OS.
Why is my phone the only one with this problem?
So about 3 days ago my phones wifi was fine. Now however I can’t use wifi. i’ve tried restarting my phone. Disconnecting and reconnecting, resetting router. Nothing seems to work. It there any reason why this is happening to only my phone?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
You said you restarted your phone. Did you try a complete hard reboot by holding down your phone's power button and selecting “Restart" from the popup menu?
If that doesn't work, try resetting your phone's network settings. Go to the Settings app and type “Reset Wi-Fi, mobile, and Bluetooth” in the Search bar. Select the option and follow the prompts.
You will be asked to re-select your Wi-Fi network to connect to it .
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Tyrell-Chan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 105
