メインコンテンツにスキップ
モデル番号 A1367/ 8, 16, 32 もしくは64 GB容量
915回答 すべてを表示
Hold switch not working after replacment
Hi
I have just replaced the volume and hold buttons on an ipod touch 4th gen. The old ones worked, but I snapped the thin cable when working on it so had to replace it. Now the volume buttons work, but the hold switch will not. I have checked the solders and they're fine. I think the replacement may be defective, because I cannot think of anything else. If anyone has any suggestions I would love to hear them as I do not want to wait three weeks for another hold switch.
thanks alot
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
If the solder is fine. Did you check for small tears in the cable?
Make sure there are no solder bridges or loose components near the solder area. If all is well you will likely have to order a new one
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
matt prior さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 587
