メインコンテンツにスキップ
The Husqvarna YTH20K46 is a 24-horsepower lawn tractor or riding lawnmower with a cutting width of 46 inches.
11回答 すべてを表示
My troybilt super bronco won’t start just cranks
I have the troybilt super bronco riding mower. It will crank but now start. If I spray cleaner in it it starts for a second and stops unless I continue to spray. This makes me think it’s the engine not getting fuel.
the tank has no clogs or kinks in the tubes. The solenoid needle going up and down just fine the carburator is new but sat for like 4 months and I sprayed carb cleaner. Still will not turn over.
PLEASE HELP
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Check your fuel filter. Then check the fuel pump. If those are good then you may have to break down the carb and do a good thorough cleaning. This includes spraying carb cleaner through all the ports in it, and verifying everything is clean. But since it only sat a few months I'm thinking fuel filter or pump is more likely.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
So fuel is going straight through to the carb but does not start until I spray. And the carb is new other then sitting for 4 or so months plus I’ve sprayed the !&&* out of it.
さんによる
So you've confirmed you are getting the proper amount of fuel? If the pump is weak or the filter clogged you might still get some, but not enough
さんによる
if you have confirmed you have proper fuel flow, then look at spark. Is your plug still good? Gapped correctly? Wrong gap can still ignite the spray but won't work right for gas. Check for proper airflow as well.
さんによる
コメントを追加
回答を追加する
DDC さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 40
今までの合計 964
