メインコンテンツにスキップ
Nest Laboratories社の第2世代のLearning Thermostat
19回答 すべてを表示
Why is the new battery not powering the device?
I received my new battery for my nest 2nd gen thermostat from I fix it. After I installed it, I charged it with a USB charger. After several hours of charging, the Nest device won’t turn on. When I plug it into the wall, I get a red blinking light at the top. I know I’m installing the battery correctly because, I was able to install the old one and get it to work. Is there a problem with the device or the battery? Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
your best bet would be to contact customer support about getting a replacement battery. sounds faulty. ifixit is usually good about solving this for you.
good luck
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Brad Burns さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 20
