メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
General MotorsのThetaプラットフォームをベースにしたChevroletのクロスオーバーSUV、Chevrolet Equinoxの初代モデル。
What is the name of this part and/or what’s it responsible for?
画像
I have no clue if that’s actually gonna show up as an image and not just text but it’s directly to the left of the regulator and there’s a hose coming from it that goes to the engine. It cracked in half and had been making a rattling noise so my mom taped it up with electrical tape until we could figure out what it even is.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
6 件のコメント:
Am I seeing correctly? Is that attached to refrigerant lines for the AC system?
さんによる
What is that hooking up to? And what year is that vehicle and what motor? It LOOKS like a vapor canister purge valve. It takes fumes from the tank and allows them into the engine to be burned off. Part of emissions control system. Has check.engine light come on?
さんによる
So it’s a 2008 and it’s an LT and the engine says 3400. I don’t know much else unfortunately
さんによる
There’s a hose going from it to the engine
さんによる
The AC is working perfectly though
さんによる
1以上のコメントを表示
コメントを追加
1 件の回答
@jennasun
If it has a pipe going in and a pipe coming out AND has electrical connectors as well, then it is a canister purge solenoid or as @brandon_k called a purge valve. It normally has a mounting bracket with a rubber gasket to stop it from moving around and make clicking noise when you're driving around.
It is responsible for storing vapour that occur when the fuel is exposed to air. It allows the gas to expand and escape to this unit until the engine starts up and this vapour can be burnt via the normal combustion.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jenna Case さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 17
今までの合計 378
