メインコンテンツにスキップ
This is the device page for the Samsung Galaxy J7. The OS that comes stock to the device is Android OS v5.1.
170回答 すべてを表示
How to connect a USB device and charge the phone
Using a USB camera to feed video to my phone. I had planed to use it for a rear view on my ebike. The ebike has a charging port. I would like to use the ebike charging port to keep the phone charged. They work one at a time. What do I need?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi @tdavid7socal ,
What is the make and model number of the e-bike?
A USB hub (example only) might work but a lot depends on the what type the e-bike’s USB charge port is.
A USB 2.0 port only supplies 500mA of current @5V which may not be enough to run both the camera and keep the phone charged at the same time.
If it is a USB 3.0 port it can supply 900mA @ 5V or 1500mA @ 5V if it is a dedicated charge port only. If it is a USB 3 type, just search for USB 3 hub to get results. Again though if it isn’t a dedicated charge port it may not be able to power both at the same time.
With either you can only try and see what happens.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Tim Davis さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 24
