メインコンテンツにスキップ
Released in May of 2020, Model Numbers: SM-A217F/DS (Global), SM-A217F/DSN (Russia), Processor: Exynos 850, 3GB/4GB RAM, 6,5" inches display, 5000 mAh battery with 15W fast charging and USB type C.
108回答 すべてを表示
I took my phone to repair center for water damage and nothing happened
Hi I just want to ask a question about repairs, basically I dropped my phone in water and got it to a repair center hoping they can fully recover it, instead they offered me a screen replacement. I said no because they’re asking for 3500php (73 $) and said they’ll just clean it or remove the water that’s inside the device, I saw them spray something on the components and proceeded to piece it back together. My concern is: I’m planning to get the screen replaced next month and would that be too late and still worth it? Or will the phone survive another month. Basically what I mean is will the other parts be okay since they did something? I’ve only had the phone for two weeks btw it’s a gift from my dad.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
3件の回答
ベストアンサー
Liquid damage in electronics is like cancer. It needs to be treated immediately. Keep in mind that regardless of the technician’s skill, they can’t 100% repair liquid damage and most repair shops won’t offer any kind of warranty for liquid damage so it could work fine for an hour then die and you’ll be out the money. You might be better off recovering the data and purchasing a new unit.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
Most repair shops won't even work on water damaged phones because once they are wet they can still corrode over time. The only reason they will work on phones is to retrieve data and photos. I would take it to another shop and get the data out of it but if you don't want any data or pictures I would buy another phone.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Personally, if it was my phone - and a gift from my dad - I'd take the chance on replacing the screen. I don't know how much it will cost you in the Philippines, but here in the US they're fairly inexpensive; I just looked one up on another question and found it for about $24 USD on Amazon after a very cursory search.
Amazon.com: for Samsung A21s Screen Replacement kit for Samsung Galaxy a21s a217 Screen Replacement 2020 SM-A217M/DS LCD Display Touch Digitizer Assembly 6.5 Inch (A21S with Frame) : Cell Phones & Accessories
There are a couple of reasons for my thinking. First, your quick action it taking it to a repair shop immediately was a good call; assuming they did a good job of flushing the water out hopefully they saved it from further damage, at least as much as possible. Secondly, if it's still working next month when you're ready to replace the screen, that's a good indicator that it may well continue to work in the future.
The fact that the screen failed immediately is not surprising; it's very common for screens to die when exposed to liquids. One other item you might consider is the battery; usually it's recommended that the battery be replaced whenever it's been exposed to liquid.
Good luck; let us know what you decide and how it all turns out for you!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
jeth.agbayani さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 26
過去 30 日: 89
今までの合計 1,589
