Samsung PN60F8500 Power Died
I own a Samsung 2013 F8500 Plasma 60” tv and it no longer powers up. No red blinking indicator light, nothing. It was showing signs of this over the past week when it shut off, but after I unplugged it and plugged in again, it worked. Few days later it went off at night but the next morning it came back on by itself and remained on all day before deciding it was finished and then died. Now, it’s truly dead. I’ve tried a few things like unplugging/plugging in, taking batteries out of remote/unplug and press power button for 30 seconds, etc. I even have a second power cord for it and tried that. Nothing. Knowing parts are very rare now I did find recommended capacitors online which will arrive in a couple days, and I searched for a power board replacement and luckily there was only one on eBay for my model. It came from a working set and this was a new listing. Since I’ve heard the power board seems to be the problem 80% of the time, and this was probably rare to find available, I pulled the trigger and now that’s expected to arrive in a few days. I guess my next step will be replacing the power board with the one I bought and hopefully that will do the trick. From what I read it’s just a matter of many screws and a couple cables to unplug and then replug in. I’m a novice but I think even I can do that (with power disconnected). If that doesn’t fix it then I may need to get it to a pro because sodering capacitors, etc. is not my specialty. Before buying the power board I suppose I could have checked the fuse first by itself but I like to play it safe and I felt I was lucky to see that board on eBay after searching high and low online for it and coming up empty. I’m trying to hold onto this amazing tv as long as I can before throwing in the towel and buying a new one. Anyway, I’m certainly open to any tips or advice from you experts out there who have the time. Thanks.
Have you opened it up yet? Could you take pictures of the individuals boards inside the TV?
honakrisi さんによる
I wasn't planning to open it up yet until the power board arrives and I'm closer to replacing it. The board arrives Friday so I'd say over the weekend I'll take off the back and see what's what. I can send a response with photos when I get there. Thanks for the response.
Rick さんによる
No problem. Hopefully you will be able to fix it with the new board. If not, there are few things you can check to narrow down the problem.
honakrisi さんによる
Do you think it would be fine to remove the back with the tv vertically standing up and stablized on its stand, or should I lay it face down on a cushioned surface and do it that way?
Rick さんによる
Some tvs can remain standingup whilst all the screws are out (usually Panasonic plasmas) but on the samsungs you might need to removevthe stand to access all te srews
honakrisi さんによる
5件以上のコメントを表示
