メインコンテンツにスキップ
Lenovoのスリムで小型のYogatwo-in-oneの形式に従い、Lenovo IdeaPad Flex 5-1570は、Intel Core i5-8250U1.6GHzプロセッサーと統合されたIntelUHD Graphics620ビデオアダプターを使用して優れたパフォーマンスを提供します。
10回答 すべてを表示
Can the Lenovo IdeaPad Flex 5-1570 Keyboard be Replaced?
My Lenovo IdeaPad Flex 5-1570 80XB keyboard has a few keys that no longer respond. I bought a compatible replacement part on Amazon. It arrived with about 20 holes in it. I thought the holes aligned with something for it to snap into place. Searching further online yields very little about replacing this model’s keyboard. One site says the keyboard is riveted into the palm rest and is not removable. Can this model’s keyboard truly be replaced? If so, how? Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @ncdad ,
The keyboard is part of the upper case assembly and it has to be cut out of the assembly if you want to replace it.
Not sure with your exact model but with others it is held in with plastic rivets that can be melted or cut away so that the keyboard can be removed and then you have to glue the new one back in somehow.
It wasn’t really designed to be an easily replaceable component, separate from the upper case.
Here’s the hardware maintenance manual for the laptop. Go to p.49 to view the necessary pre-requisite steps and then the procedure to remove the upper case assembly.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
NCDad さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 42
今までの合計 3,231
