メインコンテンツにスキップ
2017年4月に発売されたSamsungの大型版フラグシップモデルGalaxy S8+です。
167回答 すべてを表示
Vertical lines on OLED due to cracked glass
I dropped my phone numerous times in the past and today it fell where there was no glass. A white line appeared and pressing does nothing. I removed some of the cracked glass but nothing changed. I plan to replace the glass but do I also need to replace the OlED display? Or will removing the the glass fix the problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
if youre getting lines on the screen youll need to replace the screen. removing glass will only make things worse. please dont remove anymore glass. get the phone repair or replace the screen as soon as possible. if it still responds to touch then atleast the digitizer still works.
im not sure if those screens come with the digitizer built in as one module or not.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
the glass on a S8 plus can be replaced and there are kits to do it as well as you tube videos that show how.
The job is extremely difficult and (strangely) easier if the glass is quite broken.
But if there are vertical lines already on the screen the entire display assembly needs to be replaced.
I tried replacing the glass on a s8 plus but damaged the extremely fragile and sensitive ribbon at the bottom of the
display... creating the same vertical lines ,
so .yes possible but very difficult
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
zwresn さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 34
今までの合計 456
