cold start sensor location
My 190 i6 is very hard to start when cold. Were is the sensor located that enriches the fuel mixture? It runs fine after warming up,.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The cold start valve is normally located on the intake manifold or somewhere close to that. It has a fuel line and an electrical connector, and looks alot like a fuel Injector. But they normally only operate below 0° from what I found. And only for 12 seconds. If it has problems running until warm i would also check the coolant temp sensor.
このアンサーは役に立ちましたか?
Try to find a Chiltons or Haynes manual for your car. They are invaluable tools for working on vehicles.
I put some Marvel Mystery oil in the gas, don't know what it does but the car starts fine now.
過去 24時間: 5
過去 7 日: 6
過去 30 日: 17
今までの合計 965
