iPhone not charging after repair
Hello,
I repaired my black glass as well as my battery. Everything seems to be ok and the phone boots up and the battery has a charge because it turns on. However, when I try to charge it, nothing will show that it is charging. I suspect that I damaged the wireless charging coil during the back glass repair but I can not get the wired charging port to charge either. Could the charging coil be preventing the wired charger from charging? Do I need to replace the charging coil or could it be something else? I decided to disconnect the wireless charging coil from the logic board thinking that this might help. When I first plugged the phone in it worked and started to charge. However, quickly after that the phone will not recognize any charging. Any suggestions?
