メインコンテンツにスキップ
No Wifi with closed lid
MacBook Pro 15" 2.16GHz Core Duo Model A1150
I mostly use my MBP in "closed-lid mode" and connected to an external monitor. The problem is the 802.11 signals cuts out when the lid is fully shut. Not completely, but it's either sporadic or "trickles", because a web page will take about 5 mins to load. Therefore, I have to open the lid a few inches to be able to use wifi. It sucks. Another possibly related problem is that the hinge is loose.
Bluetooth signal quality always sucked, but I've learned to live with it. I like my Mac, but shame on Apple for the expensive power supplies with connectors that break so easily.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Replace your antennae cable: [リンクされた製品が存在しない、もしくは無効: IF185-089]
このアンサーは役に立ちましたか?
スコア 5
5 件のコメント:
Thanks Mayer. Hopefully I can find one up here in Canada. Any idea how they fail? I've got the antenna module in my hand but I don't see any damage at all. The corner contact on the Airport board which appears to connect the shield to the MBP chassis looks quite oxidized though.
さんによる
It worked! I ordered an antenna assembly from powerbookmedic.com for $0.95 + $2.86 S+H, installed it, and now my wifi works with the lid closed. Thank you so much, mayer. . . Now if only my bluetooth keyboard and mouse would work better together with the wifi :(
さんによる
Dear Joe, That's great that you go tit running especially at that price. Now write another question and tell us about your keyboard and mouse ;-)
さんによる
I celebrated too soon. The problem is back today.
さんによる
コメントを追加
回答を追加する
Joe さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 1,691
