メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル A1001 または A1025 / 667 MHz、800 MHz、867 MHz、または 1.0 GHz G4 プロセッサ
Why can't I get past the gray screen?
Panic mode has set in!
Have done the following:
1. Disconnect, test peripheral devices and network cables. Made no difference.
2. Perform a Safe Boot. Would not perform a safe boot.
3. Reset the NVRAM/PRAM. Made no difference.
4. Start from your Mac OS X Install disc; use Disk Utility. Won't do it.
5. Check your cables and power source. Made no difference.
6. Remove third-party RAM and internal hardware. Made no difference.
7. Perform an Archive and Install installation of Mac OS X. Can't do it.
8. Perform an Erase and Install installation of Mac OS X as a last resort. Not willing to do that, because I really need a couple of things that are sitting on my hard drive.
Is there anything I can do to retrieve the information that I need from the hard drive?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
3件の回答
ベストアンサー
Get to another mac and start up in target mode. Connect via firewire cable, start the bad machine holding down the "T" key. It should bring the hard drive up on the other machine. Get your data off first. Then run disk utilities. Also check remedies listed on Apple's site for gray screen: http://support.apple.com/kb/TS2570
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
Referring to your question at the end it is very easy with your computer to remove the hard drive and put it in a external drive to transfer files. I'm including the URL for the hard drive removal process. Ralph
PowerBook G4 Titanium DVI ハードドライブの交換
Have you reset the PMU? I'm including the URL from Apple on how to do so. You might try that first. Ralph
http://support.apple.com/kb/HT1431
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I need to do a Target Disc Mode from my broken screen Tibook to a Macbook please explain how to do it.
Thanks Woody
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Cathy Burwood さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 5,154
