メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
任天堂スイッチは、ドッキングステーションを介してテレビで遊んだり、外出先で遊んだりできる携帯型ゲーム機です。2017年3月3日に発売されました。
PowerA controller not pairing
Hi, I had to send my joycons to get fixed (drift much) and I had a PowerA enhanced wireless controller connected and paired to the switch so I kept on using it and had no problem even without the joycons. Until I decided to try and connect it to my PC and to do so I unpaired from the switch, now I'm trying to connect back to the switch and it does not pair! Has anyone seen this before? Do I need the joycons to pair it back? I'm using the touch controls in the change grip order to pair it with no luck, I already followed the steps correctly. What am I doing wrong?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Trying the “find controllers” feature could work to connect them, or maybe if the controller has a sync button try that. I don’t know if you have the power-A controller that uses batteries or has the usb-c port, but if it can run with a wire try that maybe. I hope that helps somewhat
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I have the one with batteries, no wire connection possible. I tried the sync button and the lights in controller indicate it is in syncing mode but it never comes up in the switch in the change order/grip screen! Thanks for the answer though ?
さんによる
I guess find controllers is your best bet, since you didn't mention that you tried that. If the switch remembers a controller, and you hold on it in the menu, as long as the controller is nearby and has battery power it is forced to connect. I had this same issue on my pro controller a while back
さんによる
コメントを追加
回答を追加する
Felipe Akira さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 33
今までの合計 1,952
