メインコンテンツにスキップ
2017年9月に発売されました。モデル番号はA1863、A1905。GSM もしくはCDMA/容量は64か256GB/ゴールド、シルバーとスペースグレイ
877回答 すべてを表示
iPhone 8 front microphone noise
The front microphone makes a noise for the first 2-3 seconds of the call/video and then starts working normally. I tried replacing the proximity cable but the problem persists. There are no other issues with the phone. Could this be audio IC?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Are you certain it’s the front microphone on the proximity sensor? There’s a total of 4 mics in the 8. Two at the bottom attached to the charge port, one at the top attached to the proximity sensor, and one by the rear camera. You also may have received a defective proximity sensor assembly depending on where you sourced it from.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yes because it only occurs when I record a video with the front camera. I tested the mics by recording videos (front and rear), voice memos (I thing it uses the bottom mics) and calls. Could it be that the new proximity sensor assembly had the exact same issue as the original? It also seems like its camera is faulty because it’s blurry.
Besides the proximity sensor assembly could it be something else?
さんによる
コメントを追加
I have the same exact problem with my iPhone 8. Just replaced the front camera cable and the problem persists! It can’t be the same exact problem with this new cable! It’s so much noise in the background that doesn’t allow the actual sounds getting recorded! I need help with this! Anyone?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
UnluckyJoe さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 106
