Apple Watch Series 5 Compatibility
just wondering.. will a motherboard of an apple watch series 5 40mm, work with a series 5 44mm case/display? if yes, what are the advantages and disadvantages of doing so?
Display will work, but bottom and right side of the display will be grey as size 40mm motherboard is not expected to work with 44mm display.
Housing- im afraid you will not be able to properly install it inside as the size is different and screws placement will not be compatibile.
Anwsering your question, it will work but you will have only disadvantages from such thing.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 74
