メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPhoneの第2世代モデル。モデル番号はA1241 / 8 もしくは16 GBの容量/ ブラックもしくはホワイトのプラスチック製背面ケース。修理はオリジナルiPhoneに比べて直接パーツに作業ができます。ドライバー、こじ開けるためのツールと吸盤カップが必要です。
Power button randomly presses itself
Hi guys,
Got a randomly rebooting iPhone 3G here that worked fine docked for some reason.
Replaced the battery using the guide found on this site.
Back together the phone worked fine but it kept locking itself and showing the power off slide bar. I have a feeling that the power button presses itself randomly or something.
What can I do to fix this except cleaning the buttons and hoping that that works? Going to try that later today.
Update
Ive cleaned the power button and the power button contacts. The button stil doesnt work. Im trying to take the phone apart again to see if it solves the problem.
Volume buttons work fine as does the vibration switch. Could it still be the flex that is broken or is it more likely the actual button isnt making contact with the flex.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント
I have removed cable 5 from the logic board. The problem is gone so next step is to try and take apart the button and clean it or install a new flex.
さんによる
コメントを追加
2件の回答
最も参考になった回答
You first need to find out wether it is actually the button itself that is causing the issue or something else. Try this:
Remove the connector #5 which is connecting the power button to the mainboard with a powered phone. Check if the problem still persists:
- Problem is gone → There is a problem with the physical power button. Replace this flex to solve the problem or you might try to disassemble the power button and clean between the metal of the button and the gold traces on the flex.
- Problem still persists → Problem with your logic board. Had this one time before. Ultrasonic cleaned the Logic board solved the problem that time.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
+ good clear explanation.
さんによる
コメントを追加
sometimes the center middle dimple gets pushed out of center. remove and use clear light scotch tape and re install metal dimple back to the center position. worked for me. good luck
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Stefan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 8
今までの合計 3,475
