How do you fix a stickey L3 joystick?
My L3 joystick is sticking to the left as if I am doing it. When I lift my thumb it keeps moving left or turning my shooter. Is there a repair or fix and where can I get the info. Yjanks
so when you take your thumb off does the thumb stick pop back to neutral?
have you spilt anything on it recently? you may need to open it up and clean out the joy sticks.
that’s not too terribly hard to do.
if the thumb stick does not pop back to place then you may have to either resolder a new thumb stick.
if its moving when the thumb comes back to neutral and it still drifts unfortunately the thumb stick has stick drift, usually you can set dead zones in games to reduce how bad it drifts but it’ll only get worse with time.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 68
