メインコンテンツにスキップ
Sprint, U.S. Cellular, and Alltell CDMA version of the HTC Touch Pro (RAPH800).
1回答 すべてを表示
締切られた回答
How do you test electronic components?
I've got a dead electronic device (HTC Touch Pro CDMA to be exact, but I'm looking for a more general solution) and am trying to figure out exactly what's wrong. I own a multimeter, but don't know precisely how to use it to test the various boards to see exactly what's wrong and what to replace. I expected there to be a Guide on here about this, similar to the soldering guide, but I can't seem to find one.
Help?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Here are some good tutorials http://www.ladyada.net/learn/multimeter/ and http://www.sparkfun.com/tutorials/202. Now to test the SMD I'd invest in one of these http://www.extech.com/instruments/produc... Here http://poeth.com/smtmfg.htm and here are good tutorial on the SMD http://www.fpga4fun.com/external/SMD/smd... and http://poeth.com/smtmfg.htm Hope this is going to help you out. Big issue with any of the devices will be that a schematic is going to be very useful, but not always available. I do recommend that you start building yourself a file library and keep/get as many schematics as possible. The probable reason for the lack of a guide that you are looking for is the vast amount of different boards. Each manufacturer likes to protect there boards from copying etc.... Hope this makes sense...:-) Good Luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 6
今までの合計 664
