メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
廉価版で携帯バージョン、統合されたJoy-Conコントローラと若干縮小したスクリーンを持つNintendo Switchハードウェアです。2019年9月20日発売。
Troubleshooting Game Card Reader Error
I was intermittently getting errors reading game cards but it was mostly working.
Unrelated to the game card reader error I broke a joystick and replaced both joysticks myself. The joystick repair seemed to go fine and is working after the repair, but of course I had to basically take apart everything to get to it. After being pleased that the joysticks work I realized that the game card reader no longer works at all (no game cards work in it).
I was thinking this is unrelated to my previous intermittent errors because it’s now happening on every card. And since I just took apart the entire switch I figured that I must have damaged the game card reader’s cable during my repair. I took it apart again and the I couldn’t find any apparent physical damage to the game card reader. I tried reseating the cable but alas it still didn’t work with any game cards..
I thought maybe I couldn’t see the damage to the game card reader so I ordered a new game card reader, installed it, but I am still seeing the error on every card. I tried reseating the cable on the new game card reader to be sure, but it did not help.
Is there anything else to do?
I suppose it’s possible that the replacement game card reader is defective but how could I know for sure? Is there any way to determine if the replacement game card reader is defective or if the issue is elsewhere?
Do you think I damaged it in the repair or do you think it’s related to the original intermittent card reader errors I was seeing before the joystick repair? But more to the point, how can I troubleshoot this? If it’s not the game card reader, could it be anything else besides the motherboard? I assume if it’s the motherboard then the switch is basically not repairable as I don’t even see replacement motherboards really available, right?
Any ideas? Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Probably just random issue, getting a replacement would be the best, aswell as a cable if it’s not included
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ian さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 368
