メインコンテンツにスキップ
The Dodge Journey is a mid-size crossover SUV manufactured and marketed by FCA's Dodge brand since model year 2009, with a mild facelift for 2011 model-year.
27回答 すべてを表示
No heat in the front, but heat works in the rear.
We just bought a 2012 Dodge journey SXT two wheel drive v6. We were told that the car had a blower motor issue in the front before we bought it. I have replaced the blower motor and the resistor. Now the fans in the front work but there is no heat coming out of either side in the dash. The heat in the rear still works fine.
What do you think the issue is
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
4 件のコメント:
Currently having same issue Actuator has been replaced and it still blows cold air (in front half) rear heat works fine
さんによる
I figured it the problem with my car and recorded this https://youtu.be/N4hxHT84Rpc
Maybe it will help
さんによる
would that be a diy ?
さんによる
Yes. Long story short the blender door actuator moves the blend door. My blend door broke so the actuator was moving nothing. I knocked a hole in the HVAC housing to move the door for heat.
さんによる
コメントを追加
1 件の回答
It could be a valve in the coolant hose, it could be a blend door actuator which lets in air from the heater core and the ac evaporator and moves it so certain amount of air comes in from one or the other so it's at the temperature you requested. I believe dodge had problems with the blend door actuator. I would look for technical services bulletins to if there was an issue with your vehicle.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Would you say its a diy?
さんによる
It can be some are easier to get to but I believe that the 94 to 2001 trucks took 4 to 6 hours by the book rate so I would look up the labor time or get a manual and see how hard it is. I have had to pull dashes off of cars to access heater parts. I haven't worked on cars professionally for 10 years so I'm not up to date on your model but it could be buried or it could be right in the front.
さんによる
コメントを追加
回答を追加する
Justin Cease さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 32
今までの合計 2,196
