メインコンテンツにスキップ
Scientific Casio Calculator released August 2000. Identified by the model name FX-115MS
7回答 すべてを表示
Why won’t it use the battery?
I know the version I have (Casio fx-115 ES Plus 2nd Edition) is solar powered, but I thought that it could at least store power or use it’s battery when it’s not directly under a light source? As of now, it won’t turn on unless it’s directly under a light source…
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
It is possible that this model doesn’t have a battery. Many calculators are 100% solar powered.
However, if this model does have a battery, the battery is probably dead and needs to be replaced. These batteries are usually not rechargeable even though there is a solar panel. Over time, the battery will die.
If there is a battery compartment or cover on the back, then it is simple to replace the batteries. Otherwise you may have to take the whole thing apart (assuming it has a battery in the first place).
Hope this helps.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
yasmeen さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 16
今までの合計 1,168
