Maytag Wont run Full Cleanwasher Cycle
The cycle is 1:03 min, it starts and then jumps to 10 min. Bravos top loader #MVWB300WQ0…
Hi @vmahdy ,
Try resetting the cycle settings back to their factory default settings and check if that resolves the problem.
Here’s the procedure:
i). Press Power/Cancel, then select Drain & Spin cycle.
ii). Press Extra Rinse > Fabric Softener > Extra Rinse > Fabric Softener within 5 seconds. If you get the timing right i.e. pressing the button sequence within the time limit, then the 7-segment display will show “Fd” for 3 seconds and the washer will then return to the Standby Mode
このアンサーは役に立ちましたか?
Thank you so much!! That reset worked!
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 47
