メインコンテンツにスキップ
Why will my laptop not power on?
I accidentally dropped my laptop and the screen started glitching. I turned it off then right back on and it was fine. I then closed the my laptop and when I went to use it again it would no longer turn on. I’ve plugged it up and nothing. No lights come on whatsoever.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
When you connect the power do you see a light indicating that it is charging. Usually blue or amber? Steps to try
1: Try from different outlet
2: Try from different power connector (If possible)
3: Clean power input with alcohol with qutip and try again
4: If under warranty you may need to send it in. If not under warranty you may need to open laptop inners and check that power connect is connected to motherboard.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
stephyrm1985 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 7
今までの合計 81
