How do I replace a damaged LCD screen on Lenovo IdeaPad 3
How do I replace the LCD screen on my Lenovo IdealPad 3 ?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @heychapmom,
Here’s the hardware maintenance manual for the laptop, taken from this webpage
Go to p.51 to view the necessary pre-requisite steps and then the procedure to remove / replace the LCD panel.
Here’s the parts list for the laptop.
Click on Select Commodity > LCD Panel (12) to find the part numbers for all the compatible LCD panels for the laptop.
Search online using the part number only to get results for suppliers of the part that suit you best. Usually the Lenovo part number can be found somewhere on the back of the LCD panel if you wish to verify that you are ordering the same type of panel as the original
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 12
今までの合計 444
