メインコンテンツにスキップ
2017年6月17日発売。A1418 / EMC 3068 / 2017 / 2.3 GHz デュアルコア i5プロセッサ 。
2400 MHz RAM in a 2133 iMac?
I am looking to upgrade the iMac to 32 GB of RAM, but most of the kits I see seem to be 2400 MHz, intended for the retina model 21.5” from this year.
It should be fine to use the faster speed in this model, correct?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Please tell us the exact machine you are referencing. OR You can look it up yourself here:
https://everymac.com/systems/apple/imac/...
UPDATE
RAM Type:PC4-17000 DDR4*Min. RAM Speed:2133 MHz
Details:*Apple reports that this model ships standard with 8 GB of "2133 MHz DDR4 onboard memory." Thankfully, however, this is not entirely accurate.
Standard RAM:8 GBMaximum RAM:16 GB*
Details:*8 GB of RAM is standard and reported as onboard with an optional upgrade to 16 GB of RAM at the time of purchase for an extra US$200.
In a pleasant surprise, as first discovered by site sponsor OWC, this memory actually is not onboard and can be replaced or upgraded after the initial purchase of the Mac, it's just unnecessarily complicated.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Apple iMac 21.5-Inch "Core i5" 2.3 (Mid-2017) Specs
Identifiers: Mid-2017 - MMQA2LL/A* - iMac18,1 - A1418 - 3068
さんによる
Hello Jon, did you upgrade your iMac with 2400 modules? Im looking for 2133 and I dont find anything on the market.
さんによる
コメントを追加
I have your model and everything I’ve read even the box says 2133 but I opened it up and the sticks themselves are 2400T
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jon さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 13
今までの合計 709
