メインコンテンツにスキップ
冷凍庫を含む冷蔵庫の修理と解体ガイド。
1696回答 すべてを表示
am trying to remove back panel in freezer to defrost ice buildup
I have lg French door refrigerator model #LMXS30776D/02 and am trying to remove back panel in freezer to defrost ice buildup. This happened once before while unit under warranty and recall repair man somehow using a hair dryer to defrost. How do I remove that panel. No screws are evident
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I have same fridge same problem.
Replaced pcb,seals and fan housing.
Still have to manually defrost. Did you ever solve
The problem with your fridge?
Heard their were heated fans? Maybe insulation
Foam stops water drainage?
さんによる
コメントを追加
2件の回答
最も参考になった回答
Hi @valerio57 ,
Here’s a page from the LMXS30776S service manual that may help, (see Fan and Fan motor section) I realize that it is a different model but the model number is nearly the same and it seems very similar in design.
If there is an ice build up on the freezer evaporator unit then there is a problem with the defrost system as this shouldn’t occur. Removing the ice with a hair dryer is only a temporary solution as it does not address the cause of the problem.
Also do not use the hair dryer on hot setting to melt the ice build up as it may damage the evaporator unit. It is only thin Aluminium and designed for freezing cold temperatures and not really hot ones. Allow the ice to melt naturally and only occasionally use the hair dryer on the coolest setting to speed things up.
Here’s a link that shows how to check for an error code which may help to find out what is happening. Hopefully the procedure is the same for your model.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
hair dryers and heat guns will MELT the plastic parts and liners even when careful only way to go portable garment steamer sold on amazon for 30$.
Hers how to remove step 1 unplug unit. step 2 remove freezer drawer via rails 3 use steamer and shop vac to clear any and all ice and water you can get at(be through and patient) 4 use a pair of needle nose vice grips grab upper grill vent port and pull out and down if it will not move defrost some more! there are several at least 2 connectors from back panel to fridge i can think of wires will have to be unplugged to remove whole back panel (fan and thermister)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Suzanne Balettie さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 23
過去 30 日: 94
今までの合計 3,643
