Will I need to replace the screen adhesive after a battery fix?
This is one of my first replacements, and I’d like to know if my Surface Pro 4 will function as intended after a battery replacement without adding new adhesive.
It will function, but you need some adhesive to secure the screen to the chassis. Not only to keep it in place, but the Surface tablets are a bit sensitive to ‘ghost touching’. Securely mounting the screen helps here. You can use thin general purpose double adhesive tape (3M black for example), it comes in various sizes. Clean first!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 55
