Can I change the ssd card on this to add more storage on it?
I have a Acer chromebook 14 and I was wondering if I can change the 32 ssd for a 256 ssd to install windows 10 as a virtual machine on it
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If you can change the motherboard with one that has a different storage limit you can change the storage on it.But you need a USB recovery tool from the Chrome recovery utility on the web store since you wont have a os.
このアンサーは役に立ちましたか?
Most Chromebooks use eMMC, so not likely. If you see a M.2 slot it might work, but it will likely always require keeping the base 32GB of eMMC if it can be done, in addition to the add-on SSD.
More than likely, it will be fixed (non-upgradeable) eMMC. Outside of a few like the Acer C710 (mSATA) I’ve never seen a modular SSD in a Chromebook.
Yep. It’s soldered.
このアンサーは役に立ちましたか?
Thx.I decided instead I could put it on ebay and buy and buy a asus chromebook flip c436.Does that one have a ssd.
@mrfixer2011 Also eMMC.
Oh Really.Then how do you explain on Best Buy and Amazon that they have different storage limits on it.
For asus chromebook flip c436 best buy
https://www.bestbuy.com/site/asus-chrome...
For asus chromebook flip c436 amazon
@mrfixer2011 Different boards.
過去 24時間: 1
過去 7 日: 1
過去 30 日: 6
今までの合計 381
3 件のコメント
What is the exact model? Have you opened it up to have a look? Does it have an SSD or M.2 drive installed? If it does. . .maybe.
mike さんによる
The specific model is cb3 431 c3ws .
Arvin Klair さんによる
@mrfixer2011 Found a photo of the board... Soldered.
Nick さんによる
