メインコンテンツにスキップ
The Sony Alpha NEX-C3 can be identified by its model number: NEXC3K/B. It was released in 2011. The Sony Alpha NEX-C3 has a 18-55mm wide-angle lens and a 16.2 MP Exmor APS HD CMOS image sensor.
2回答 すべてを表示
How do I repair the USB jack on my Sony NEX-C3 camera?
The jack where I plug in the USB cable is loose and does not seat tightly to the case or when a cable is plugged in. Result is that camera is rarely detected when plugged into computer USB jack. Does the whole motherboard need to come out in order to fix?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi Robin,
I think what you have is a USB port that got partly broken off the motherboard and hence the loose connection. If you are able to open your camera to expose the USB socket you will see the pins lifted off the board and/or having broken connection on some of the pins.
If you have the tools (soldering iron and some solder), you could repair it yourself.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Robin Goldstein さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 6
過去 30 日: 10
今までの合計 132
