メインコンテンツにスキップ
モデル番号 A1051 / 4 もしくは6 GB ハードドライブ
87回答 すべてを表示
How do you know if the battery health has been deteriorate
Hi I have an iPod mini 2nd Generation. The battery has been holding quite well, I haven’t seen any battery drain yet but I am a bit worried if it doesn’t hold up since it is still an original battery, especially worried on expanded battery
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
選択されたソリューション
You can check the battery stats of your iPod, iPhone or iPad by installing Coconut Battery on yourMac and Hooking up to a USB port and running it.
https://www.coconut-flavour.com/coconutb...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It depends on how long have you had this for and how often did you charge and drained the battery. I think when the 2nd gen Mini came out Apple was bragging about the battery which was holding more than double the charge than the 1st gen. I think it is rated for 18 hours audio playback.
Now, since these are quite old device, don’t expect the battery to last that long, but I would imagine it should still hold around 8-10 hours playback, again, depending on the intensity that you have been using your device.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
lincolnchia さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 22
今までの合計 399
