メインコンテンツにスキップ
Repair guides and disassembly information for the Samsung Galaxy A51 Android smartphone. Released in January of 2020.
20回答 すべてを表示
Flex’s / shields on middle frame .
Could someone explain what all the brown flex’s / tape / shields are on the middle frame of the phone are used for , what are they ? Could someone explain what each one is .? Does it matter they got damaged when removing the back .? Have it marked in picture
Update (03/05/2021)
I have attached a picture on the one that got damaged .? It’s not the NFC one
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Hi,
They are the NFC antenna as well as some other antennas.
If one of them got damaged you may have signalling problems, either with GSM or NFC depending on which one was damaged.
Here’s the ifixit Samsung Galaxy A51 Teardown guide, see Step 3.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I have attached pic above if you know what this one does .?
さんによる
Hi @l83
I don't know. I have done further research and I'm sure that it is not for the WiFi or BT (have amended my answer above).
Also I cannot find the individual component as a spare part, but if you can't find it either then here's the part number for the mid frame GH98-45033B.
If you search online using this part number "only" in the search box, you will get results for suppliers
さんによる
コメントを追加
I have same problem but mine is upper part and lower part of golden circute is damage when I open back cover. If that is broken it will cause any problem ?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
L83 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 761
