メインコンテンツにスキップ
Samsung Galaxy Note 20 5G アンドロイドスマートフォンの修理と解体情報です。2020年8月発売。
20回答 すべてを表示
stuck n sh*t outta luck Samsung Galaxy N20 5G
So my old man surprised me with the latest from Samsung. the note 20 5G, unfortunately whom ever he bought it from failed to tell him that there is a sim stuck in the phone w/o the sim tray. he did tell him that the tray was “the ONLY” thing missing so we ordered new phone cases, sim tray, protective gear screen, camera, and case{“Otter Box"] plus an extra sim card but cant use none of it if i cant retrieve or dislodge the sim PLEASE ANY HELLLLP
thank you
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi,
The safest way is to open the phone and get to the SIM card that way.
Trying to remove it from the outside will most probably only damage the card reader. Also doing it this way could possibly cause electrical problems, even if the phone is switched off, because the card may be shifting across the board and shorting out things as it is being moved, which normally would not happen if it were in a tray.
There is always power available on the systemboard when the phone is off. The power on/off button is not a power isolating button. Its function is to signal the OS what the user wants to do. Think of the phone being in an extremely low power state when off and that it is not isolated from any power supply i.e. the battery
Here’s a teardown video for the phone which may help.
If doing this yourself seems too daunting, contact a reputable, professional mobile phone repair service and ask for a quote. Given how new the model is, in the end it may be worth doing it this way as the repairer will have the necessary tools and expertise to do the repair. Also they will bear the responsibility if it goes wrong.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Can't stress enough the importance of reputable professional. Not everyone owning a phone repair shop is a professional. In the end they could just do what jayeff said not to do and damage the phone further
さんによる
コメントを追加
回答を追加する
Kelly Jonesbeaumont さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 45
今までの合計 1,207
